SFP+ cable - which one?
I only know the basics of networking and completely new to anything sfp+.
Can anyone offer any advice as to which cable would be appropriate to purchase.
I read that there are complications when trying to mix transceivers, and that I should maybe use a copper direct attach cable?
I’m temporarily trying to connect a mini workstation to an old switch, to try and get out of a rather sticky situation that’s not of my doing.
The cable needs to be 3-5 meters.
the very old switch is a brocade-vdx-6720:
10 Gbps SFP+ options: 1/3/5 m direct-attached copper (Twinax)
10 GbE SR and 10 GbE LR
and the new device is a Minisforum MS-01, that uses a Intel X710 10G SFP+
any advice is welcome, i’m in the uk so any suggestions on vendors would be great too.
thanks,
10 Pounds is about as fair a price as you’ll get for a 3M twinax, unless you buy in bulk …
Before spending a lot of money on cables et all, I heard not very good stories about Brocade devices that make them (for me!) a no-go solution. For one, they have a scheme that requires you to purchase a licence (!!) to enable ports and/or other networking related functionality. If you’re trying to connect your machine to the Brocade switch, make sure the port is enabled!
Thanks for the info and the link! £10 is cheap, I thought they’d be £50-70. Without going into too much detail, it’s a very old switch that we’re desperate to get off at work as it’s causing us a lot of issues. Connecting this mini workstation for a few days will allow us to move away from it.
I’d read about receivers not working well with each other so wanted to check before I bought the wrong one that wouldn’t connect to both of the rather specific devices. Im more concerned about the wasted time than money.
Thanks again
Another good place to get fiber and SFP cable supplies:
https://www.fs.com/c/10-25g-dac-aoc-2869
Brocade should use “generic” transceiver coding, and so work with any transceiver. Generally speaking, only Cisco and Juniper of big name brands lock down their transceivers to special models that need the right identifier coding.
SR is short range, and uses “multimode” wavelengths, LR is long range and uses “singlemode” wavelengths. You cannot mix them together, you need to stay either with MM for all your transceivers or SM for them all. If using SM, be sure and use the shortest distance models as the longer range ones (many tens of kilometer range) can blow out the transceiver when used on a distance of a few feet due to how strong the signal is. Typically inside offices or homes use MM transceivers as the distances are more suited to inside of buildings type of lengths. Each type of transceiver also uses its own fiber optic lines, optimized for that wavelength. So it is important to stick with all 1 type for a deployment.
When using Twinax/DAC cables you dont worry about MM and SM, as they are their own thing and a complete package, not just a transceiver.
It’s more the case of switches requiring a transceiver to handshake in a specific way, Brocade ones don’t do that AFAIK (and I own one …)
That is true for the VDX series (the one the op needs to work with), whereas for the ICX series there’s a lot of love on the servethehome forum, with detailed instructions/links to get them running properly and with updated firmwares, also a lot of knowledge regarding how to silence them … I am running an ICX-7250 POE since more than a year now as my main home switch, the most difficult part in using it was making the ‘proprietary’ console cable by sacrificing a mini-usb and and a serial cable and join three wires …
10G stuff can be really hit or miss as far as what transceivers work with what switches. I’ve found the 10GTek stuff works really well. I’ve used their transceivers+fiber as well as directly attached copper cables and they’ve worked on my Intel cards and MikroTik/Ubiquiti switches.
