Hey yall, so i just got my hands on an RTX A5000 and wanting to do a Mini SFF CCTV Capture / AI detection machine for my new home with blueIris, and would like to do a SFF rig to sit on my desk, would like it be semi silent as it will be on desk and wondering what the route would be for this, looking at something like;
although if i should make some changes id happily take some advice from people who know what they are doing better than me!
Not really sure why you would want to get that Streacom case when a Dan A4 or Loque Ghost is a third the size. Also consider the 7600 over the 7600X for lower thermals. Also, 500 GB for a boot drive in 2023 is just being cheap.
So, something like this, maybe? Similar build. Cooling should be adequate since it is pretty much an open air chassi. Might want to dust it off with some pressurized air every once in a while, though.
