So I have an old 42 inch 768p TV. I want to use it for like a second screen while I'm gaming so I can go on the internet or something. it doesn't connect with DVI. but I have a DVI to VGA, and that VGA leads to a HDMI cable. is it possible?
Nope, you'd need some kind of active converter box to go from analog to digital
But I'll assume the TV has an HDMI in then right? Just get a dvi->hdmi or display port->hdmi
oh okay :P ill buy a dvi to hdmi adapter.
like I tried it. and it detects the tv but it shows nothing
You tried VGA to HDMI?
This is strange. So you're wanting to connect dvi from your gpu, to a vga adapter to a hdmi adapter, then to your tv?
yes lol
Then why not just do dvi to hdmi? xD
Because I don't have a dvi to hdmi conector :P
Buy one. They're affordable. lol
There's your problem @DemonLordCIPHER lol
Let's go from digital adapter to analog back to digital and cross our fingers.
Does your TV not a a (PC) VGA in?
it does but I cant find a VGA cable lol
