Hi all,
I am looking to help out a few local schools with a distance learning initiative the have asked for. The school isnt in the best neighborhood and budget cuts arent helping the situation much.
The current plan is to use a hikvision ip cam mounted on the ceiling pointed at the blackboard. And setup the laptop to connect to the rtsp stream as a webcam, where they may select it as an video stream when teaching math etc.
So far I have found splitcam to be acceptable but id like to have the setup require as minimum an intervention as possible. The app requires teachers to run and does not have a trey icon. Ive read a lot about direct show drivers and the like and looked at IP Video Source: 64-bit version, resolution flexibility, Adobe FMLE – Fooling Around . however they are limited in terms of source streams.
Has anyone attempted anything similar…
