Setting up my first AD that i’ll be using for vmware horizonview, was curious if anyone had any tips or best practices for domain naming and what not for a nearly total newb.
Seems like reasonable advice to me. A long time ago I once created an AD server in my lab for private internal use only, forgot about it, changed some network switches around (which allowed traffic out) and then wondered WTF was going on with my labs IP ranges. Turns out I’d picked a name that someone else had registered externally and some automatic stuff happened. For a while they had less IP addresses available
Basically yes, whilst at a basic level your NAT router will stop it being presented on your public IP address (unless you set up port forwarding) no one will connect to you, but if someone else has that domain registered and you allow the AD server access to the internet you will run into issues.
