Windows 10
Anyways, enough of that before it clutters up this thread.
Windows 10
Been foolinā around with this today. How do you deal with NAT in this configuration?
I set this up on pfSense and had all of my traffic tunneling through Linode. I ended up making a firewall rule/outbound NAT rules to force my server subnet to egress out of my regular WAN because I couldnāt get my portforwards to work. I had to write similar rules to make my wifeās PS4 work properly because she couldnāt play Crash CTR anymore lolā¦
So that depends on the host right? We have a second thread
Infrastructure Series -- Wireguard Site to Site Tunnel
But overall on pfSense it generates NAT rules by default from what I read.. OPNsense does not..
By default OPNsense will not disable routes and let you make those decisions for yourself..
On linux you will find the same default. I summize there is potentially an issue with how you setup the PFsense firewall. Consult both threads. If you cant figure it out. Post your config (on either this thread or the other I linked) sans keys and see if someone can spot something
(Please noted in that thread IPv6 routing is not detailed)
iptables -D FORWARD -i %i -j ACCEPT; # In
iptables -D FORWARD -o %i -j ACCEPT; # Out
iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE; # NAT MASQ
#ip6tables -D FORWARD -i %i -j ACCEPT; # 6 in
#ip6tables -D FORWARD -o %i -j ACCEPT; # 6 out
#ip6tables -t nat -D POSTROUTING -o eth0 -j MASQUERADE # NAT 6 MASQ
(I havent quite figured out IP6 to IP6 wireguard yet. This will take exploration) but this should be a enough to get you started looking in the correct direction.
