Self hosted music library, considering Lidify but curious what people are using?
I ran into Lidify and thought it looks interesting. I’m curious if anyone is using this and what they’re experience is? Or what your goto self-hosted music is?
I like that this supports audiobooks which jellyfin doesn’t afaik.
There is currently no mobile app but the PWA support seems functional in this case.
Also since Lidify had its first release in December it doesn’t have much maturity so that’s some points off in the security assessment.
I personally use audiobookshelf for local podcast and audio books and host a navidrome server for all other local music. There’s an app for audiobookshelf (on android at least) and any app that can stream from subsonic servers will work with navidrome.
Thanks! Audiobookshelf looks great!
Here is a useful reddit thread
https://www.reddit.com/r/selfhosted/comments/1q6wdn3/lidify_selfhosted_spotify_alternative_with/?show=original
Also there are other projects named Lidify, like this one
The name is used in reference to Lidarr in other cases but apparently not in the one i linked.
Oh will probably pass on Lidify for now based on the lack of maturity but will keep an eye out f it grows into something.
Still nice to hear what tools people are using!
I don’t have any audiobooks or podcasts self-hosted, just music. Navidrome.
Jellyfin supports Audiobooks in the Books library type:
How well I don’t know since I don’t have any audiobooks.
I use it for my music too, but the 10.11 release has some performance issues with mid-sized to large libraries. For me it’s not a big deal, for others it is, YMMV.
I checked Navidrome twice and it didn’t bother to even follow the one single setting I made, so I don’t feel confident in it ever doing what I want :person_shrugging:
I use Jellyfin for all of my selfhosted content. It is just simpler for me to have a single app instead of spreading everything across multiple apps. I doubt it performs the best in each content type, but convenience is king.
Another nod to Jellyfin, and also Emby.
I have an awesome method.
It’s called “folder on my NAS with all my media shared on my local network”.
The best part is there is no app, no database, no syncing, no annoying XML files, no anything, and it just works! :sweat_smile:
As any true engineer knows, the simplest solution is always the best solution.
Depending on how many other users someone has, this may not be the best way.
Until it doesn’t.
Besides, half of what a media server is used for is the UI including eye candy like movie/show posters.
That’s what the front end is for. The backend is just a datastore. Anything can do that.
If you have many “users” it sounds more like you are running a piracy service than hosting your media library. :sweat_smile:
Don’t do that.
Don’t you call my mom a pirate ha!
All it really takes is having more than one person at home that wants to access the same content. They also provide a lot of other quality of life features such transcoding so streaming remotely isn’t a big problem.
That is definitely an assumption of all time.
Users can simply refer to different devices too.
Case in point, I use my media library not only on my (Linux) PC, but also on Xbox and on my Android phone and on my Steamdeck. It is infinitely easier to sync watch states and importing the media in the first place with a Jellyfin server on the NAS.
And Kodi has also had a longstanding bug where adding an NFS mount ironically doesn’t work on Linux devices while it does on Windows devices, so I literally cannot use an NFS mount on Android or Steamdeck.
And to the “just use SMB duh” crowd: no.
But regardless of all of that, the question was specifically about a media server, and dismissing the OPs question and just saying “don’t use one” seems a little… well… dismissive.
If it’s enough for you that’s all well and good, but different users have different needs.
I’m enjoying navidrome. It’s an implementation of the widely used subsonic protocol. Lots of clients to choose from. On desktop I just use the built in webui, on ios I really like arpeggi (Join the Arpeggi beta - TestFlight - Apple)
I would host audiobooks separately with audiobookshelf. Separation of concerns, audiobooks and music are similar only in that they’re both audio.
Lidify seems to be built more around Music discovery rather than music management
Although the thing I’d like to see in Jellyfin (and any other player like VLC for mobile and “desktop”) is a way to display all that metadata I’ve imported to the files through MusicBrainz/Picard. And a plugin to index/cross-reference all my Touhou Doujin music on the Jellyfin server.
I still (eventually) need to migrate my Jellyfin server to a non-Fedora system so I can finish kicking out the last RedHat-related systems out of the house.
This, but Airsonic. It might be getting a bit long in the tooth though.
Airsonic works great, and with play:Sub on iOS. Unfortunately the app is not free but there are alts that are still good.
I recommend, if you are using docker, the kagemomiji fork
