So as the title states I am looking for a mini itx board that will support ECC and allow me to pass-through the one PCIe slot and NVMe. I’ll be using a NVMe to PCIe x4 adapter. So the the board will need to have a NVMe slot. I’ve had my eyes set on the ASRock Fatal1ty AB350. I believe ASRock boards support ECC but I am not sure about the IOMMU grouping of the PCIe slot and NVMe.
So using the PCIe for more NVMe storage? Or is there an adapter to use a GPU with an NVMe M.2 port?
If the former, you’ll have to use a 2200G/2400G and none of the boards I’ve seen so far will support ECC for the non-pro models (which I can’t find anywhere yet).
Well that certainly clarifies things! FWIW I believe the Biostar allows for PCIe bifurcation as an option (2x8 lanes) but I have no idea how that translates for IOMMU groupings.
I also want to do the same thing though, but for a media server/router, except of course a 2200G would be perfect with the exception of no ECC support :-/
ESXi with the following VMs: pfsense, Debian (Docker, Snapraid, Mergerfs), Windows 10. I’ll need to pass-through the HBA to the Debian VM and a network adapter to the pfsense VM.
I would really like if motherboard manufacturers would stop with the whole “Gaming” branding. It’s a joke!
I’ve been avoiding this but I may have to take the hit. I’ve owned the X10SDV-TLN4F before. I was hoping to use a Ryzen with higher clock speeds and lower price tag. But the X10SDV-TLN4F has all the features I’m seeking aside from the CPU and price.
Thanks, that’s the 4 core version and it does not include the two 1gbe ports. I had this board in the past as well. I had attempted to use it as a desktop computer. It just couldn’t cut it. At least not for my desktop usage.
