Hello network wizards of Level1 -
Can anyone recommend a software define networking solution which can do VXLANs or GENEVE tunnels?
Basically, is there a FOSS alternative to VMWare NSX-T?
Most respectfully,
Cotton
Most respectfully,
Cotton
Open vSwitch?
OpenFlow ftw
That’s just a protocol? Anything Foss it runs on except open vSwitch?
I’ll have to give this another shot. I’ve prototyped SDN network bridging with open vswitch, but I though there was something “magical” about vxlan bridging.
Turns out it’s just a tunnel interface on a vm for the most part.
I still got a lot to learn about SDN.
SDN is a very ambiguous term. It’s appropriate to use the “nail jello to a wall” metaphor trying to get a precise definition.
VXLAN is basically tunneling Ethernet frames over UDP. It has also been paired with EVPN acting as a control plane to improve MAC learning by propagating it via BGP. This is a significant improvement over the “flood and learn” method when you get into larger networks. FRR has support for EVPN and can be used with VXLAN on Linux, here is a post I found with some information.
That is very helpful!
Thanks!
Yeah, I think I replied to cotton when I meant to reply to you. OpenvSwitch running on OpenFlow ftw lol.
Thanks for making me look stupid
