Hey guys,
So my internet failed. Yes, I have tried turning it off and on again.
This link shows my current network setup for my home work office thats has been working for over 2 years.
The internet has failed on me recently. I have isolated that the problem is the switch. Once te switch is connected, together with the devices, the whole network’s internet fails. Once the switch is removed, LAN network and wifi works. I have replaced the switch once already, but the problem ensues.
The simple solution is to connect the devices directly to the router, but the router doesn’t have enough ports to support the devices.
Can you be more specific about what is connected to the switch and how it’s connected? If your network is crashing then it could be a broadcast storm cause by the switch being connected to itself somehow.
An example of what could cause this is if you have two cables connecting the switch to the router instead of just one.
I once had similar issues with some too cheap switches I acquired. I had to disable auto negotiation of link speed, in your case, it should be in the router.
I had two switches that didn’t want to work. Whenever I connected them, my LAN crashed. Switches worked fine alone, router worked fine alone, together it all went tits up. After sifting through logs, I found out that for some reason, the router kept changing link speed from 100Mbit to 1000Mbit, back and forth. Until all networking, after a short while, stopped working. I fixed this, by forcing link speed on router to 1000Mbit.
On a side note, also had this happen once with a usb > Lan dongle. Same fix as above.
Ah…thanks for the help guys…so i have further isolated that it isnt the switch…
so one of the desktops, a ASRock deskmini installed with ubuntu 18.04 LTS.
I previously had Pop installed on it, and there was no problem then (yet). I installed ubuntu 18.04 last week, the problem surfaced. I can kinda confirm this because the system log file from the router showed that the firewall was triggered, and that when the ubuntu pc LAN was connected, the LAN system fails.
