I recently purchased the PAAG-E3122B KVM. Everything is going well so far (by that I mean all of my issues far have been PEBCAK, which means this one may as well!), however I am having one particular issue regarding connecting the second monitor to the display that I have not been able to resolve.
Both monitors are connected to the correct inputs on the KVM, and each will work when connected to the first DP input - connecting either to the secondary KVM monitor input appears to do nothing. Even having only one monitor connected to this second DP input on the KVM results in no image.
Whichever monitor connected to the working DP input is detected and displayed, while whichever one connected to the second DP input is not.
Note that there are no monitors or unknown devices detected in Device Manager - and the monitor does not detect any input.
This issue is the same whether I am connected to the first pc (home desktop, DP cable from graphics card to KVM) or my work laptop (HDMI to DP adapter with external USB power).
Tried:
Swapping cables - no change
Updating display drivers - no change
Connecting directly to graphics card - this works
Please let me know what other information may be relevant - or what silly things I have forgotten.
KVM Back DP Description:
Top - DP to desktop Graphics Card
Middle - DP to HDMI Adapter (Laptop)
Bottom Left - Primary Monitor DP (works)
Bottom Right - Secondary Monitor DP (does not work)
Had to drop one of the photos, as I can only upload two as a new user.
ok so you need a second DP connection from each computer into the KVM for the second monitor to work? Otherwise the bandwidth would be limited to what a single DP connection can do.
Uou can use an active HDMI to DP adapter (usb powered) probably to get the second connection on the desktop. Looks like maybe that’s what is on the laptop?
so hook that up to your desktop and confirm you get two displays on your desktop, one hdmi, one dp?
