Search Small Business Router?
Hello,I am working on a small busines and want to buy a new router. I want the new router to be able to support wireless,VPN and if it is possible VLAN. I also try to use cisco 1941W router on Router-Switch .Does someone who had used this router ?
You need a router, access point, and switch.  All of them should be separate pieces of hardware.
http://www.ubnt.com/edgemax#edge-router-poe
for my small business i am using a cisco e1000 with ww-drt. it has everything you mentioned exped vlan (not sure on it)
e1000 should do VLANs as well, as it is based on a broadcom chipset. Mine does, at least. It doesn't do fancy stuff like gigabit or N, but it has bee rock solid for me. Beats the crap out of my gimpy Belkin N gigabit router...
I agree 100% with this post.
Cisco 1941W has built- in VPN capabilities, which create a secure remote connection for remote access over the internet.
