Hey all. I have an ASRock WRX80 Creator R2.0 with a Threadripper Pro 5955WX (16C/32T). I’m testing out the Seagate Firecuda 530 (2TB variant) as it seems like the best NVMe gen4 SSD right now (for write/endurance).
When the drive is used in a gen4 (4x4x4x4x) PCIe bifurcation card, I get the full 7.4GB/s read, 6.9GB/s write speed from the drive (Q8T1).
However, when used in the motherboard M2_2 (slot 2), I’m only getting 6.4GB/s read/write speeds (Q8T1):
Temps are within spec (39C idle, ~60C load writing), so there is no throttling. I feel like it’s hitting some arbitrary hard-coded wall here.
Now, I understand that M2_2 (slot 2) is connected to the WRX80 chipset, and not to the CPU directly (as with M2_1 (slot1) and the PCIe slots). But slot 2 should still have a gen4 x4 connection:
Furthermore, the WRX80 chipset itself is connected to the CPU via a gen4 x8 connection, so there should be plenty of bandwidth available. I have some SATA3 drives connected (which also go through the WRX80 chipset), but I can’t imagine those even remotely saturating a gen4 x8 chipset link. I don’t have anything else connected to the WRX80 chipset.
I want to use this drive in the mobo M2_2 (slot 2) as a super fast caching drive for VM vDisks (since no redundancy). And save the PCIe lanes / bifurcation card for more important things.
What’s causing the bottleneck here?
