Hey Everyone,
I had a similar thread where I was diagnosing some disk issues ive been having… and Im back with some more details.
My Hardware:
6x ST6000NM0095 6tb Seagate SAS drives
Netapp 4486 Disk Shelf, hooked to LSI 9200-8e in Proxmox machine.
My Issue:
The drives arent Spinning up!! Ive moved them around, between machines and backplanes, and on Supermicro backplanes they spin up and work fine, but in the Netapp (where I really want them to live) they do no spin up, and dmesg reads the following:
[261297.749674] scsi 1:0:28:0: Processor MARVELL LUIGI_V2_STSB_DB 2015 PQ: 0 ANSI: 5
[261297.749684] scsi 1:0:28:0: SSP: handle(0x0020), sas_addr(0x500a098001533c95), phy(31), device_name(0x0000000000000000)
[261297.749687] scsi 1:0:28:0: enclosure logical id (0x500a0980024cfdc8), slot(23)
[261297.749760] scsi 1:0:28:0: Power-on or device reset occurred
[261297.750408] scsi 1:0:28:0: Attached scsi generic sg21 type 3
[261297.775500] scsi 1:0:28:1: Direct-Access HITACHI HUS724040ALE64DB NA01 PQ: 0 ANSI: 5
[261297.775508] scsi 1:0:28:1: SSP: handle(0x0020), sas_addr(0x500a098001533c95), phy(31), device_name(0x0000000000000000)
[261297.775511] scsi 1:0:28:1: enclosure logical id (0x500a0980024cfdc8), slot(23)
[261297.775574] scsi 1:0:28:1: Power-on or device reset occurred
[261297.776212] sd 1:0:28:1: Attached scsi generic sg22 type 0
[261297.776313] sd 1:0:28:1: [sdd] Spinning up disk...
[261298.809295] .
[261299.833318] .
[261299.833609] not responding...
[261299.833850] sd 1:0:28:1: [sdd] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[261299.833855] sd 1:0:28:1: [sdd] Sense Key : Aborted Command [current] [descriptor]
[261299.833859] sd 1:0:28:1: [sdd] Add. Sense: Internal target failure
[261299.834035] sd 1:0:28:1: [sdd] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[261299.834037] sd 1:0:28:1: [sdd] Sense Key : Aborted Command [current] [descriptor]
[261299.834040] sd 1:0:28:1: [sdd] Add. Sense: Internal target failure
[261299.834152] sd 1:0:28:1: [sdd] 0 512-byte logical blocks: (0 B/0 B)
[261299.834155] sd 1:0:28:1: [sdd] 0-byte physical blocks
[261299.834244] sd 1:0:28:1: [sdd] Write Protect is off
[261299.834247] sd 1:0:28:1: [sdd] Mode Sense: bf 00 00 08
[261299.834402] sd 1:0:28:1: [sdd] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[261299.835041] sd 1:0:28:1: [sdd] Unit Not Ready
[261299.835045] sd 1:0:28:1: [sdd] Sense Key : Aborted Command [current] [descriptor]
[261299.835048] sd 1:0:28:1: [sdd] Add. Sense: Internal target failure
[261299.835251] sd 1:0:28:1: [sdd] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[261299.835254] sd 1:0:28:1: [sdd] Sense Key : Aborted Command [current] [descriptor]
[261299.835258] sd 1:0:28:1: [sdd] Add. Sense: Internal target failure
[261299.835453] sd 1:0:28:1: [sdd] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[261299.835456] sd 1:0:28:1: [sdd] Sense Key : Aborted Command [current] [descriptor]
[261299.835459] sd 1:0:28:1: [sdd] Add. Sense: Internal target failure
[261299.835901] sd 1:0:28:1: [sdd] Attached SCSI disk
