Sata card issue after mobo upgrade (softreset FIS failed)
I am having a very odd issue after upgrading mobo/cpu from fm2 APU to 2200G. I was also using 8 port Marvel Sata card which worked without any issues for a while now. After upgrade however 2 specific ports of the card are having issues. If I hot-plug a drive all I get is this error:
ata2: softreset failed (1st FIS failed)
Drive still mounts and I have seen no other issues. When the system reboots however all drives fail to be even detected by the system if one of the 2 ports are used. When booting there are additional errors for other drives and several FIS attempts and finally timeout and giving up errors in the same format.
I have ruled out the drives, cables, back-plate, power issues so it has to be the sata card or software bug, more likely a combination of the two.
It doesn’t seem like sata card is faulty since it worked before. At the same time the motherboard works fine too and I can’t imagine what sort of defect could cause the sata card to fail in such a limited fashion.
Does anyone have any clue what is going on here?
lspci:
10:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9235 PCIe 2.0 x2 4-port SATA 6 Gb/s Controller (rev 11)
