I bought this SSD awhile ago. I never really checked the speeds as it never came to mind. Now that I've tested the speeds I'm getting 2 problems.The problem being that It is below the advertised speed on Write (200Mb/s difference) and that its very inconsistent. The speeds very around the 100 Mb/s and lower a lot. I see hiccups of 30Mb/s . Is this normal? Any help would be great.
Thank you for correcting me.
Are you running SATA 1, 2 or 3?
SATA 3.
Are you using AHCI or IDE?
IDE
Is TRIM enabled?
No
How long have you had the SSD?
Roughly A Year Now
Is this the first install on it?
No I have installed Windows on It many times
Can you check it's health with Crystal Disk Info?
Its listed as Good (100%)
How full is the drive?
