https://www.amazon.com/dp/B07CS3JGPC/?tag=level1techs-20
This is a companion discussion topic for the original entry at https://level1techs.com/video/samsung-uj59-315-4k-monitor-review
I want to know if this monitor supports HDCP 2.2 with Netflix and MS Edge. Cause reviews are not clear on HDCP 2.2 capability. You could test with Fire Stick 4K or Apple TV 4K too if you need that kind of testing outside of DisplayPort testing.
My ViewSonic advertises that it does support HDCP 2.2
Also, if you want slimmer bezels @wendell, ViewSonic is putting out a decent option here that uses the same panel as my current VX3211-4K-MHD:
