Hi,
today I got an Samsung PM9A3 U.2 and changed the sector size from 512b to 4k. After creating a zpool, I got the following error message:
“One or more devices are configured to use a non-native block size.”
[manja-02 ~]# zpool create -o ashift=12 tank02 /dev/nvme2n1
[manja-02 ~]# zpool status -v
pool: tank02
state: ONLINE
status: One or more devices are configured to use a non-native block size.
Expect reduced performance.
action: Replace affected devices with devices that support the
configured block size, or migrate data to a properly configured
pool.
config:
NAME STATE READ WRITE CKSUM
tank02 ONLINE 0 0 0
nvme2n1 ONLINE 0 0 0 block size: 4096B configured, 32768B native
errors: No known data errors
Two weeks ago I did the same with an Intel P4618 and had no problem with it.
I mean it shows that 4096 bytes are supported?
[manja-02 ~]# nvme id-ns -H /dev/nvme2n1
LBA Format 0 : Metadata Size: 0 bytes - Data Size: 512 bytes - Relative Performance: 0 Best
LBA Format 1 : Metadata Size: 0 bytes - Data Size: 4096 bytes - Relative Performance: 0 Best (in use)
[manja-02 ~]# lsblk -o NAME,MOUNTPOINT,PHY-SEC
NAME MOUNTPOIN PHY-SEC
sda 4096
├─sda1 4096
├─sda2 4096
├─sda3 4096
└─sda4 4096
sdb 512
└─sdb1 512
sdc 131072
sdd 131072
nvme0n1 4096
├─nvme0n1p1 4096
└─nvme0n1p2 4096
nvme1n1 512
├─nvme1n1p1 /boot/efi 512
└─nvme1n1p2 / 512
nvme2n1 32768
├─nvme2n1p1 32768
└─nvme2n1p9 32768
edit: back to 512b and zpool created without specifying ashift, now it supposedly has 4096b, WTF?
[manja-02 ~]# nvme format --lba=0 /dev/nvme2n1
You are about to format nvme2n1, namespace 0x1.
WARNING: Format may irrevocably delete this device's data.
You have 10 seconds to press Ctrl-C to cancel this operation.
Use the force [--force] option to suppress this warning.
Sending format operation ...
Success formatting namespace:1
[manja-02 ~]# zpool create tank02 /dev/nvme2n1
pool: tank02
state: ONLINE
config:
tank02 ONLINE 0 0 0
[manja-02 ~]#
[manja-02 ~]#
[manja-02 ~]#
[manja-02 ~]#
sda 4096
├─sda1 4096
├─sda2 4096
├─sda3 4096
└─sda4 4096
sdb 512
└─sdb1 512
sdc 131072
sdd 131072
nvme0n1 4096
├─nvme0n1p1 4096
└─nvme0n1p2 4096
nvme1n1 512
└─nvme1n1p2 / 512
nvme2n1 4096
├─nvme2n1p1 4096
└─nvme2n1p9 4096
LBA Format 0 : Metadata Size: 0 bytes - Data Size: 512 bytes - Relative Performance: 0 Best (in use)
