hey can you please help me, my galaxy s6 edge is bricked. it doesn’t turn on unless its connected to a power source, like say when i connect it to my laptop it turns on or if its plugged into an outlet. when its plugged in it doesn’t go Any further than the boot logo where it says Samsung galaxy s6 edge with red words at the top that says “recovery is not seandroid enforcing” and the only thing i can do is go into download mode where you press volume down home button and power button. when its connected to my laptop its only recognized during download mode.
You can try a factory reset, that might fix it. http://www.digitaltrends.com/mobile/how-to-factory-reset-galaxy-s6/
edit; I should note that i am no expert on this problem and you might want to wait and see if anyone else has a fix.
If that does not work try this at your own risk and if you are still in warranty it may void it. follow this guide http://forums.androidcentral.com/ambassador-guides-tips-how-s/499009-guide-samsung-how-flash-stock-rom-via-odin-new-interface.html
If you cant find the firmware on the link in the guide try to find it here http://forum.xda-developers.com/galaxy-s6-edge/general/sm-g925f-s6-firmware-thread-t3078841
If this dose not help reply and ill see if i can come up with something else.
thanks cardboardman, i followed ur directions and everything works perfectly now.
thanks to u as well b1gbadwolf.
No problem, glad to hear it worked.
