Samsung DDR4 ECC advice for 5900X
Hi, I am looking for an explanation regarding 2 types of Samsung DDR4 ECC memory modules. I am planning a build for my current gaming 5900X to be re-purposed as a workstation machine with 4x32 GB ECC 3200 MT RAM. I apologize if this topic has already been discussed.
In Samsung website, they offer 2 types of DDR4 modules:
  • M391A4G43BB1-CWE (32 GB; 2x8R; (4G x 8) x 18),
  • M391A4G43AB1-CWE (32 GB; 2x8R; (2G x 8) x 18).
What are the differences between these 4G and 2G component composition modules and what would work better for me? I am little bit lost and googling for a straight answer did not help, so asking professionals here.
Motherboard in question is Asus B550 ProArt, it does support ECC (my current MSI B550 Tomahawk does not). Thanks!
Still relevent, I would be grateful if anybody could clarify the 4G x 8 vs 2G x 8 difference… :innocent:
Sadly I don’t have a clear answer, but I think it might just be a different IC revision/configuration. It shouldn’t affect compatibility, as long as it’s udimms and not rdimm or lrdimm.
A reddit topic mentions multiple people with the BB(4G) version working on X470, with 4700GE Pro and 3700x, both on ASrock motherboards. Another topic mentioned it in conjuncture with B-die, so that may be what the A/B denote.
Sorry I don’t have a more useful answer, I’m also curious what the 2G and 4G mean, but even the whitepaper for these makes no mention of it. Other memory listings that mention Gx denote the gigabit size of a module and the number of modules, but since both are 32GB dimms across 18 dies, I have no idea how this adds up. Maybe it’s a binned down 4Gb vs full-fat 2Gb chip?
The math suggests a full-fat 4Gb module aught to result in a 64GB dimm size.
Thank you for trying to give an answer!
That is what I mean, regarding this component composition specifications, almost no information what it means and what is the difference, unless you are an engineer deep into this topic - it is all guesses. I guess I just have to write to Samsung directly :smiley:
