Samsung 870 EVO 2TB – visible in lsblk but invisible to TestDisk/GParted, SMART read fails
Hey all, hoping for some guidance. The drive has some sentimental photos/videos that I really don’t want to lose :pensive_face:
My (non-boot) Samsung 870 EVO 2TB SATA SSD started acting up after a sudden power cut. The PC hanged on the Gigabyte splash screen; after unplugging that SSD, the system worked fine.
If left, Gigabyte splash screen displays “Repairing S: drive – 100% complete,” then system boots (into Windows), but performance is unusable. Drive appears in Device Manager and File Explorer, but no data is accessible and the system is extremely slow and freezes.
Yesterday I booted into SystemRescue (via Linux USB) to investigate. Results so far:
  • lsblk shows the drive
  • TestDisk does not detect it
  • GParted doesn’t detect it either
    • Threw “error fsyncing/closing /dev/sda: input/output error”
  • smartctl does pull accurate drive info [full excerpt at bottom of post] but fails with:
    • “Read SMART Data failed: scsi error aborted command”
  • blkid, mount, and parted all gave no output
Unfortunately today when I checked, lsblk is no longer showing the drive. Perhaps I ‘poked the badger’ too much? :confused: As Ryan would say.
Next step: I’m planning to try ddrescue is this the right next step?
I only have a 1TB drive available as a destination though. Not all data on the SSD is crucial (e.g., Steam library), but the photos/videos are:
  • Is it viable/possible to recover only part of the drive to a smaller destination? Or is it better/simpler to acquire a 2TB drive?
  • Should I create an ‘image’ or does that require a full 2TB drive?
  • Any recommended workflow for this situation?
Any insight into what these errors usually point to, and any help with data recovery, would be hugely appreciated.
Sincerely,
A desperate data recoverer
=== START OF INFORMATION SECTION ===
Model Family:     Samsung based SSDs
Device Model:     Samsung SSD 870 EVO 2TB
Serial Number:    S621NG0R117578Z
LU WWN Device Id: 5 002538 f71115f7b
Firmware Version: SVT01B6Q
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.5/5706
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Jul 14 15:11:05 2026 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Status command failed: scsi error aborted command
SMART overall-health self-assessment test result: UNKNOWN!
SMART Status, Attributes and Thresholds cannot be read.
Read SMART Log Directory failed: scsi error aborted command
Read SMART Error Log failed: scsi error aborted command
Read SMART Self-test Log failed: scsi error aborted command
Selective Self-tests/Logging not supported
The above only provides legacy SMART information - try 'smartctl -x' for more
you cant choose what you are copying with block level tools like ddrescue, but if the actual data on the drive is less than
1tb you might be able to place it on a filesystem with compression enabled (btrfs for example) and all empty space will be compressed. So you can fit a 2tb image on a smaller drive in theory
if you get a 2tb drive you can use a mechanical drive too, you dont need a ssd.
Try ddrescue first so you can see if it would work or not before you buy another drive
Mounting the drive on Linux using a read only flag worked for me in situations like this in the past.
This is what I wrote down as the command in my obsidian notes the last time I needed to do something like it
Linux _ Mount bad drive in ReadOnly Mode
Sometimes you need to mount a drive in read-only mode and when it’s almost failing
sudo mount -o ro,noload /dev/sda1 /media/2tb
