Trying to access my Samba folder (Ubuntu) from local network with my Windows 10 PC. No matter which tutorial I try I get errors such as “\192.168.0.112 is not accessible. You might not have permission to use…”
At least it is asking for my credentials now. I’ve added a few users to sudo, it won’t let any of them in.
[sambashare]
comment = Samba on Ubuntu
path = home/icarus/sambashare
read only = no
browsable = yes
accessing smb shares from non window$ machines is horrible.
Heres how i set it up and no guarentees it will work.
/etc/samba/smb.conf
[Media]
comment = media
path = /media/shared/media
guest ok = no
browseable = yes
read only = no
Then on /media/shared/media.
i use.
sudo chown -R user:group /folder/name
sudo chmod 775 -R /media/shared/media
sudo chmod g+w -R /media/shared/media
it usually works, but once in a blue moon i run into some random windows installation which has to reboot 10 times and then it works, if ever.
alternately try in your file browser use the address \\192.168.0.112
that should get you there, again in my experien ces the problem is M$ handeling of network traffic, and lack of commitment to their own technology.
It should be noted i have seen this experice happen from windows to windows shares as well, M$ needs to step up their game.
so it is regardless of using linux to windows or windows to windows.
sorry fixed now didn’t know we were all anal about this.
On behalf of myself, and my ancestors i apologize trust in, i was talking to a grown up who could put together a chown command on his own, and ill repent by doing 100 shebangs in my scripts.
Note: To allow the usage of guests on public shares, one may need to appendmap to guest = Bad User in the [global] section of /etc/samba/smb.conf . A different guest account may be used instead of the default provided nobody .
from the wiki
Also you might need to enable NetBIOS/WINS host names, idk tho been ages since I used samba
i wouldn’t at worst id add a mask to the filesystem, and nothing more.
Even though smb is used as a local file share, there is still some sense of security to keep in mind.
Again from my experiences your problem is not from user right or anything, but from m$ simply sucking at their maintenance of the smb protocol.
ill wager you that you could access the hell out of that share from any linux machine 24/7, but you’d run into this on M$ machines.
Aslong as you have the read/write permissions in place then smbd don’t really care.
Thanks everyone. I can now access (some) of the files. I left it for a few hours and now it’s working. I’m not sure whose solution made the difference. I guess it was one of the changes combined with a reboot of the Windows PC.
