Hello everybody. Recently did a small upgrade and am trying to OC my cpu. However not seeming to know exactly how. I’ve looked up some guides on youtube specifically for my mobo but the settings people are changing is not changeable for me.1700x and Gigabyte Aorus Gaming K5 mobo.
I’m running Bios Version F3
After choosing Advanced Frequency Settings on the M.I.T tab,
The CPU Clock Ratio is set to Auto and I can’t figure out how to change it. Normally pressing the enter key on any setting would prompt some dialogue. The EZ Overclock Tuner worked just fine for memory.
What am I doing wrong?
Here are some pics from my bios http://imgur.com/a/rTsTL
I also tried using the Ryzem Master Application and it seemed that only 2 cores OC’d even though all of the sliders were increased the same value.
