So… New to AMD user here. My last AMD system was the Athlon 64 days. I am building a system for a friend and running into a few issues with this brand new build. I have a 3600x, ASUS C7H wifi and a Samsung 860 evo 1 TB m.2 drive. I updated to the 3004 using bios flashback without issue (all my Intel builds are ASUS boards). I am unable to get the m.2 drive to be recognized by the bios. It is installed in under the GPU just above PCI slot #1. I have scanned the bios and don’t see any sata/m.2 settings. The only thing I have seen that seems strange is under the sata section of the bios it gives you the option to rename the m.2 (grey) to any name. I don’t see any mention of only being able to use the “vertical” m.2 slot of sata any where in the manual.
My second question is in regards to ram settings/support. I have a 3600mhz g.skill kit from the QVL but I do not see anywhere in bios to select “XMP”. I see where I can manually select the frequency/timings individually of the ram. I assumed by getting a kit off the QVL it would be a set it and forget style setup. The actual end user of the PC is not very tech savy. So requiring modification/setting changes on a regular basis isn’t an option.
Thanks in advance for your help.
