hey all. so i have a ryzen 4000 laptop. (eluktronics THINN-15) i have a wd sn750 1tb NVME drive and while the laptop is plugged in i get full SSD read and write speeds. 3400 read 3000 write but when i run on battery, ssd speeds only hit 1800 read/write max
also noticed that network speeds are effected in the same way but only when i use a VPN (PIA) without VPN no issues but with vpn enabled i only get 80mbps down speed max on battery but plugged in i get 400mbps
i have a feeling that this has something to do with some sort of PCI power savings. i looked for and disabled all power saving settings that i can but no changes.
i did some googleing and saw a few posts on reddit with people with ryzen laptops having the same issue with the SSD speeds.
when i use HWinfo64 it shows the nvme drive link speed while on battery only at 5.0 GT/s vs 8.0 GT/s
how can i go about disabling this while under battery so i can have full drive speeds as well as hopfully network speeds while using my VPN
