Ryzen 3 2200G running hotter after UEFI update
Just built my grandma a new PC since hers was about a decade old and pretty crappy. Went with an ASUS B450 board, Ryzen 3 2200G and 8GB of DDR4 2400 along with a 512GB nvme SSD. Overall the system is quite fast and snappy and I’m happy with how it turned out. before I drop it off at her house though I wanted to get it all setup for her and in the process I put the latest firmware on there. I’m not sure what happened because I haven’t used an AMD platform since back when AMD’s Athlon X2 was new so there’s a few settings I’m not fully familiar with. I wasn’t able to get the CPU to turbo to it’s rated 3.7Ghz it was capped at 3.5 and since I updated the firmware it now runs at 3.7Ghz when under load all the time and instead of running at 55°C now it runs at 75°C. I find it hard to believe that 200Mhz difference in clock speed equals about 20-25°C in temperature increases. I double checked that everything in the UEFI was set to stock setting/auto.
Anyone know why it’s running hotter now?
Also total power consumption from the wall is being measured at 35 watts. That seems unreasonably low to me.
Energy efficiency has been a huge driver over the past few years. Lower energy consumption drives down datacenter costs, and improves battery life on laptops. Both matter more these days than desktops, which make up a tiny fraction of total sales now.
35 watts sounds about right with a browser open.
Source: 3dguru.com
No thoughts on the heat issues if you said you’ve confirmed everything is at stock settings.
Yea my dumbass had the monitor plugged into the power meter instead of the computer… oops. Anyways It doesn’t pass 80 watts under full load and it does clock up to 3.7Ghz correctly now. Strangely my temps are higher though after the firmware update and my core settings are the same. I’m using the stock cooler and theres no case ventelation since it doesn’t get that hot and will likely never be under a sustained full load so 70-75°C under synthetic load is fine with me however I still find it off that updating the firmware had CPU temps reporting higher. Maybe it was a bug that got fixed? Maybe temp readings were off… I’m not entirely sure. Also I’m not really familiar with Ryzen but the core voltage on auto reports it as going up to 1.4v. Obviously that’s software readings so they won’t be 100% accurate but 1.4 seems really high. My 3570K in my main rig only barely hits 1.2 on a full load with turbo enabled. in the end everything is working fine I just find the temp readings and core voltage readings a bit funny. maybe it’s fine idk.
You updated to a bios for zen2 probably, which is a shit show. Revert to whatever version was pre zen2 agesa.
It’s running AGESA 1.0.0.3ABBA.
yeah, go back to a zen+ bios and all will return to normal for you.
Alright I’ll look into it. Are higher temps a known issue? Did they alter voltage tables or something?
It seems to vary board to board and how good that manufacturer is about their bios. Basically theres no reason for you to be on the latest agesa anyway since it doesnt give any advantage to zen+.
Well it fixed the CPU not boosting at all. I think I might just stay on the latest as temps are still well within the safe range.
fair enough. what board is it? most of the horror stories I have seen have been asus or msi.
It’s an ASUS B450M-A. It’s part of their PRIME series I think. It’s a descent little board IMO. UEFI has a few minor bugs in it such as if you scroll a large screen of menus fast it runs very slow when you get near the bottom for some reason. i think it may be related to the stupid animation but it’s fine if you tap the down arrow fast.
Yeah, asus has a problem with their boosting from time to time, I’m finding out…
ask me how I know :wink:
How do you know? lul
cant really seem to get it past 4.3
Is that actually an engineering sample?
nah, misreporting.
Interesting. Idk if you have it checked but I had to enable some CPU performance boost option in the UEFI to get my CPU to boost properly. Maybe yours isn’t set to enabled. Might not have that setting too.
I’ve tried everything under the sun. I can manually push it higher but she doesn’t like doing it on her own. It’s just a bios quirk.
That sucks. But hey at the end of the day Ryzen is still pretty good even if it still has some minor growing pains. I’m hoping Zen 3 kicks ass. might upgrade my main rig with AMD next time around.
hopefully we get the ‘fine wine’
