RX 7900XTX and triple display KVM
Hello All,
I just got a triple video KVM from the L1Store. I have two machines connected, one is my work laptop on Win11 and the second is my home PC. The three displays work fine on my laptop running through a StarTech dock. I only can get one display working out of my home PC running a RX7900XTX. I suspect it isn’t the KVM, but I’m missing something to get my three displays to recognize. I’m just not sure where to go from here.
Thanks,
Marc
PC Specs:
AMD Ryzen 9950X3D
Radeon RX 7900XTX - ASRock Tai Chi
MSI Pro x870-EP
32GB DDR5
OS Linux Mint 22.2 Cinnamon (Kernel 6.14.33
Do the three monitors work with the 7900XTX without a KVM switch between them?
There’s nothing special to configure, just activate them if they are not already activated per default.
But I have never used Mint, maybe it’s different from KDE in that regard, have you tried to install “arandr” (Another XRandR GUI)?
The displays do work without the KVM, and I can get them to work with windows on my work laptop through the KVM. I’m not properly identifying the two side monitors though, so I think it’s a cable issue. I’ve tried to force output on the other DP connections but no luck.
Are there any good suggestions for a DP to DVI cable or adapter that is known to work with this KVM? My existing side monitors use DVI/VGA and I only plan to run them at 1280x1024.
I can’t promise it will work, but Delock is my first choice when I need adapters.
https://www.delock.de/produkt/62599/merkmale.html?f=s
So I’m posting an update to this situation. I’ve messed around with a few DP to DVI cables and have not been able to get the two dvi monitors to work in Linux yet. I have come to realize that the video card cannot grab the EDID from those monitors when they are connected to the KVM, but will when connected directly to my PC. I followed the discussion on another thread: How to fix "no EDID read" on Linux 5.6.0
I created a edid bin file from one of the monitors and moved it to the /usr/lib/firmware/edid folder and edited my grub parameters to load that firmware and enable the video output. Xrandr now shows the monitors as connected, my display manager tool in cinnamon also shows the screens as active, but there is no actual output to the screens. My main screen still works as expected. I’m not sure what else to try at this point. I have a second video card that I’m considering installing next to my primary to see if I can get output on these two monitors.
I finally got it working! This is a cable/adapter issue for sure. I purchased a couple of DP to VGA adapters and decided to try and use the VGA input of the monitors. One adapter from J5Create worked while the one from QVS did not. Those were the only two adapters at my local Micro Center. Best Buy didn’t have any adapters in stock and I finally made it to an Office Depot. They had one adapter from Ativa which I believe is a house brand for Office Depot and this adapter worked. The monitors transmit their EDIDs fine and no need to monkey around with firmwares or grub configurations.
