My setup::
Windows 10
python3.8
VS Code
I’m attempting to setup a python 3.8 virtual environment in Windows. I’m receiving the following error while executing the pip command when in my (venv) environment.
These are steps I took to create the venv:
python -m venv C:\Users\Rich\Documents\dev\python\venv
when in the Scripts directory I did - activate.bat
Now my terminal in VS Code shows (venv)
I then executed pip freeze which gives the following error:
(venv) C:\Users\Rich\Documents\dev\python\venv\Scripts>pip freeze
Traceback (most recent call last):
- File “C:\Users\Rich\AppData\Local\Programs\Python\Python38\Lib\runpy.py”, line 192, in _run_module_as_main*
- return _run_code(code, main_globals, None,*
- File “C:\Users\Rich\AppData\Local\Programs\Python\Python38\Lib\runpy.py”, line 85, in _run_code*
- exec(code, run_globals)*
- File “C:\Users\Rich\Documents\dev\python\venv\Scripts\pip.exe_main_.py”, line 9, in *
TypeError: ‘module’ object is not callable
how do I execute pip while in a venv?
