I recently watched a video in which Wendell kinda convinced me that I should make my own VPN server. So I started to give it a try without any Linux knowledge whatsoever. But I just couldn't find a guide that provided all required steps for me (as a complete Linux noob) to do it. The biggest problems seem to be that OpenVPN and easy-rsa came kind of preinstalled with my server and I installed these anyways and also, I dont have things like systemd, so for example I couldn't run systemctl restart [email protected].
I literally spent hours trying to all this to work. But in the end the only thing that seemed to work was the certificate generation.
But after editing a lot of files, generating client keys just failed with:
Please edit the vars script to reflect your configuration,
then source it with "source ./vars".
Next, to start with a fresh PKI configuration and to delete any
previous certificates and keys, run "./clean-all".
Finally, you can run this tool (pkitool) to build certificates/keys.
...which wasn't mentioned in the guides that I looked at...
and starting OpenVPN with service openvpn restart (of which I don't even know if it would start OpenVPN as server) failed too:
[FAIL] VPN 'server' is not running ... failed!
[email protected]:/etc# service openvpn restart
[ ok ] Stopping virtual private network daemon:.
[....] Starting virtual private network daemon: serverSIOCSIFADDR: No such device
: ERROR while getting interface flags: No such device
SIOCSIFDSTADDR: No such device
SIOCSIFMTU: No such device
failed!
I copied and moved so many files and installed/uninstalled openvpn etc so often that I don't even know how to revert my changes and start from scratch. I don't think I have the rights to instal a different OS on the server and I can't even use the sudo command. But I can use the root account.
So maybe someone of you could tell me how to get OpenVPN running on Debian wheezy. I'm just falling into despair. :(
