Looking to get parts for running LLM locally. Currently, I’ve setup in my Proxmox server Ollama + Webui running on a RTX 2070 Super (8GB). I’ve been running smaller 4B parameter models and not really happy with the results. I’m looking to upgrade the setup and run qwen 3.6 27B parameter and use Hermes + MCP servers.
I’m looking at using a better GPU and using whatever parts I have around. Currently I have a rx 7900xt (20GB) in my gaming computer and am probably going to get a rx 9070xt to replace it and use the rx7900xt for running LLMs. That or possibly getting a GPU for LLMs but what I’ve seen for pricing on used 3090, 4090, AI PRO R9700 and Arc B70, they are $2k+ CAD (I’m in Canada). I was debating on getting a B60 as it has more VRAM and is about $1k CAD which is not bad but it’s much less powerful than my GPU. I’m open to any recs on a GPU that’s $1.5K CAD or setups that can cover up to that.
For hosting the LLM, I’m thinking of doing bare-metal Ubuntu Server using parts I have around or can get cheap:
- AMD Ryzen 5 5500 (will be picking this up or getting a similar AM4 socket CPU)
- B550 ATX Motherboard
- 32GB of DDR4 3200MHz RAM
- 512GB M.2 Gen 3 NVME
- 1000W Gold PSU
- RX 7900xt (20GB VRAM)
Would this be a sufficient setup?
I will have to pickup a Ryzen 5000 CPU as I do not have a spare one but the rest of the parts I have on hand. I do have a Ryzen 7 1700x CPU but have not tested if it’s compatible with B550 Motherboard. If I use a Chinese X99 board with a E5-2680 v4 CPU that has 64GB 2133 MHz ECC Ram, would that be better than what I’m thinking of? I don’t like the overall power draw from the Xeons and slower RAM speeds but I have these parts lying around. Any real difference if I do bare-metal vs hosting in VM with GPU passthrough on Proxmox?
I’ve got a budget of $1500 CAD I’m willing to drop now on parts and then possibly more in 6 months if prices are stable enough.
Any guidance or advice on this will be greatly appreciated. Thanks.
