Soā¦ Previous Nvidia cards Iāve had presented as 2 devices. One graphics device and one audio device. The ānewā extra two are the serial bus (which I assume is the RGB controller), and a usb controller.
To my surprise, the usb type-c port on the back of the card actually functions as a full fledged usb port, so Iām able to connect a usb3 hub to it using a ātype-c to aā adapter and no longer need to pass through an additional pci-e usb card!
The hub is being powered by the usb port, and has a keyboard, mouse and usb DAC connected with zero issues.
Seeing as these cards are quite new and virtualization is a bit niche, I thought Iād put this down in a post for people to see.
Yeppers, the USB port is intended for VR. Itās called VirtualLink, passes through video, audio, data, and power to a VR headset with a single cable. But you can use it as a normal USB 3.1 port, attach a hub, etc. Would be really nice for eGPU use also, once it makes it down to cheaper cards.
You mean like plugging an eGPU into the internal GPU? Would be amazing if this could make some bizarre CrossFire work but that just imagination.
Or just having the card basically sitting on the desk with just external power and USB-C connecting it to the PC. That actually sounds really cool, a raw card, no PCIe plugged in just power and USB and it works, but I donāt know how that would or even if it can work like that.
I thought eGPU enclosures needed thunderbolt 3? This is just USB 3.1 gen2 I believe? Maybe with some fairydust sprinkled on top in this case with it being called a āVirtualLinkā port.
VirtualLink is designed to enable a new level of immersion in VR, with power, display, and data bandwidth specified to meet the needs of future VR headsets. That includes support for four lanes of HBR3 DisplayPort for high-resolution displays, USB 3.1 Gen2 (SuperSpeed USB 10Gbps) for headset cameras and sensors, and up to 27 Watts of power delivery.
I have seen some posts on the UnRaid forum where people have passed through a thunderbolt 3 PCIe card and had an external GPU enclosure plugged in though. But thats a little off topic
Soā¦ now this has had chance to sink inā¦ something like this (link below) would mean a VM, with ONLY the graphics card passed through (no vfio NIC either) could get Display, SD Card reader, USB, Audio and Ethernet from a single usb type-c cable out of the back of the graphics card:
Only thing im not sure about is whatās driving the monitors plugged into thatā¦ whether thereās some kind of cheap-o GPU built into the hub, or iāll get driven by the 20series card?
For a host running multiple VMs (especially those who need to be on different networks), this would be pretty cool.
Essentially takes away the need to set up networking on the VMs on the host (as you can plug a physical Ethernet cable into each) too.
if youāre running 10GbE on the host, youāll be sacrificing some bandwidth obviously, but being able to run everything from a single cable out of the GPU is pretty interesting!
You were right the first time. This could be plugged into the 20xx card but it would only be USB-C 3.1 Gen 2. Mac has thunderbolt 3 so can pass its own display/graphics through this dock, I donāt think the 20xx cards could.
No, Iām talking about TB3 eGPU enclosures. Many of the cheaper ones donāt have USB ports built in, which kinda takes away the point of the things, where one cable does everything.
This is some next level. In other scenarios. It would be nice for anybody with restricted physical pcie or a small form factor iGPU+dedicated setup. Sadly the new Vega doesnāt have this feature.
