RTX 5080 stuck at PCIe 5.0 x8 on ASUS TUF Z790-Plus WiFi
Hello everyone,
I’m looking for some advice regarding an issue with my new system.
System Specifications:
  • CPU: Intel Core i9-14900KF
  • GPU: ASUS ROG Astral RTX 5080 OC 16GB (DOOM Edition)
  • Motherboard: ASUS TUF Gaming Z790-Plus WiFi
  • BIOS: 1836 (latest)
  • RAM: 32GB Corsair Vengeance DDR5-6000
  • SSD: Samsung 990 Pro 2TB (PCIe Gen4)
  • Windows 11 Pro
GPU-Z consistently reports:
PCIe x16 5.0 @ x8 5.0
I have already performed the following troubleshooting:
  • Updated BIOS to the latest version.
  • Installed the latest NVIDIA drivers.
  • Cleared CMOS.
  • Reseated the GPU.
  • Verified all power connectors.
  • Enabled the GPU-Z Render Test, and it still reports PCIe 5.0 x8.
  • The Samsung 990 Pro is a PCIe Gen4 SSD, and according to the ASUS manual, the M.2_1 slot should not reduce the primary PCIe x16 slot to x8.
  • Best Buy inspected the system and did not identify any obvious installation issues.
At this point I’m trying to determine whether this could be:
  • A motherboard issue
  • CPU/socket (LGA1700) issue
  • BIOS bug
  • GPU issue
  • Or expected behavior with this hardware combination
Unfortunately, I don’t have another GPU available to test.
Has anyone experienced this with an ASUS Z790 motherboard or an RTX 5080?
Any suggestions would be greatly appreciated.
Thank you!
I took al look at the motherboard manual and some stuff.
Do you have anything plugged in the most bottom slot of the motherboard?
It shares 8 lanes with the top gpu slot.
Also just to be sure can you try moving the ssd from M.2_1 to a different slot?
It should not steal lanes but it might cause some interference who knows.
If non of the above had results lets go for more unlikely stuff
Oh btw can you post a photo of you board? Maybe I spot something unusual on it relating to this issue.
BIOS bug uncommon but they happen yes, maybe 8x8 split is enabled by default for some reason (Not the first time ASUS made a oopsy with a bios update and did not notice multiple version releases.)
The bios setting we need to check is located on the advanced tab within the Onboard Devices Configuration menu.
It’s the top option named “PCIe Bandwidth Bifurcation Configuration”. Bios docs topic 6.15
It should be by default on auto mode, if not we found the cause.
If auto have a check if any other mode are available in the menu like a x16 mode.
Usually you only got auto and x8/x8 mode.
Last thing to try before to start considering hardware issue is to reseat the cpu.
Only annoying part is you need to re apply thermal past as you have to remove the cpu cooler.
I recommend Noctua nt-2th or Artic mx-5 if you don’t know what to get.
Btw did you build the system yourself, or was it build to order?
If build to order do you know what thermal paste they used? As it is not uncommon for the more boutique builders to use liquid metal instead of regular thermal paste on 14900k.
Liquid metal can be devastating to you motherboard if it happens to spill, and cleaning it is also a pain.
