RTX 2070 with DVI and usb-c?
I’m currently looking for an RTX 2070 for an nzxt h1 build I’m going to make. I want to use oculus link with it but I can’t find any reliable m-it’s motherboards with a usb-c output. I also need DVI because my monitor (Acer GN246HL) only supports 144hz with that output. Honestly any gpu that is around as good as a 2070 (super or not) would be fine.
From the brief look I took, it looks like No. Most are HDMI and Display Port. Not all of them have the USB port either.
This does have the USB port but like many others is 3x DP and 1x HDMI
Probably easier and much more suitable options wise to get an adaptor, like this:
Though I don’t know if there are limitations in converting them with an adaptor, Gonna have to do a little legwork yourself there. It looks it can work but you want dual link and ingeneral make sure it will do 144Hz.
