Recently switched back to full time Linux from Windows and the only issue that i’m having is the usb audio output for the Rodecaster Pro is garbled. See following link for a recording of the output.
I’m currently running manjaro on the 5.12 kernel so it is after the alsa patches for the rodecaster to set it to 48000 hz. Input audio sounds fine from the rodecaster with the default settings for pulseaudio in manjaro. I’ve tried running through all of the troubleshooting steps in the audio quality section of the arch troubleshooting page here. I’ve also tried running jack and it has the same issue.
Looking for any further tips on troubleshooting the issue.
here’s the pacmd list-sinks output:
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY
state: IDLE
suspend cause: (none)
priority: 9048
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 100.11 ms
max request: 37 KiB
max rewind: 37 KiB
monitor source: 0
sample spec: s32le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
fixed latency: 99.94 ms
card: 0 <alsa_card.usb-RODE_Microphones_RODECaster_Pro_00000000001A-01>
module: 6
properties:
alsa.resolution_bits = “32”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “USB Audio”
alsa.id = “USB Audio”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “3”
alsa.card_name = “RODECaster Pro”
alsa.long_card_name = “RODE Microphones RODECaster Pro at usb-0000:0b:00.3-4.4.3, high speed”
alsa.driver_name = “snd_usb_audio”
device.bus_path = “pci-0000:0b:00.3-usb-0:4.4.3:1.1”
sysfs.path = “/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:0b:00.3/usb3/3-4/3-4.4/3-4.4.3/3-4.4.3:1.1/sound/card3”
udev.id = “usb-RODE_Microphones_RODECaster_Pro_00000000001A-01”
device.bus = “usb”
device.vendor.id = “19f7”
device.vendor.name = “RODE Microphones”
device.product.id = “0011”
device.product.name = “RODECaster Pro”
device.serial = “RODE_Microphones_RODECaster_Pro_00000000001A”
device.string = “iec958:3”
device.buffering.buffer_size = “38376”
device.buffering.fragment_size = “9592”
device.access_mode = “mmap”
device.profile.name = “iec958-stereo”
device.profile.description = “Digital Stereo (IEC958)”
device.description = “RODECaster Pro Digital Stereo (IEC958)”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-usb”
ports:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <iec958-stereo-output>
