This drives me crazy at work at the moment, I have wasted waay to much time on it. My routing Table looks like this:
Route Codes: R - RIP Derived, O - OSPF Derived, C -
Connected, K - Kernel, S - Static
B - BGP Derived, E - Externally Derived, IA - OSPF Inter Area
E1 - OSPF External Type 1, E2 - OSPF External Type 2
N1 - OSPF NSSA External Type 1, N2 - OSPF NSSA External
Type 2
S U - Unnumbered Peer, L - Leaked Route, T - Truncated
ECMP Route
* Indicates the best (lowest metric) route for the subnet.
No default gateway is configured.
C *172.24.0.0/16 [0/0] directly connected, Vl2
C *172.25.0.0/16 [0/0] directly connected, Vl4
however, if I run a traceroute from the switch to another device, I get the following:
console#traceroute 172.24.4.4
Traceroute to 172.24.4.4 ,30 hops max 0 byte packets:
1 0.0.0.0 * * *
2 0.0.0.0 * *
Hop Count = 2 Last TTL = 2 Test attempt = 5 Test Success = 0
Does anyone have a clue on what is going on? Pinging the Gateway or even the Gateway to the other VLAN from a Computer connected to the switch works fine, but they can’t ping each other either…
They are connected to those Interfaces:
interface Gi1/0/2
switchport access vlan 4
exit
interface Gi1/0/46
switchport access vlan 2
exit
