Are there any rgb xl mouse pads that can be controlled through iCUE, Dragon Center, or RGBFusion 2.0? I really don’t want to have to install yet another piece of RGB software.
Build your own? doesnt seem like it would be too rough
Acrylic base, rgb strips and xl mouse pad
Could use an arduino of some sort to control fading/color changing, or just good old dimmer on transistors.
I’m in the business of selling anime rgb desk mats. Your idea is quite inspiring—perhaps we need a unified RGB configuration software and standard. This could save industry resources and open up a standardized interface, allowing everyone to enjoy creative RGB effects.
Yes, there are a few RGB XL mouse pads that are compatible with popular software like iCUE, Dragon Center, or RGBFusion 2.0, though compatibility depends on the brand. For iCUE, look for products from Corsair, such as the Corsair MM700 RGB Extended. For RGBFusion 2.0, Gigabyte peripherals like the Aorus AMP500 RGB are a good choice. MSI’s Agility GD60 might integrate well with Dragon Center. Always double-check the product details or reviews to confirm compatibility, as some pads only support their proprietary software. This will help you avoid installing extra RGB management tools!
