So I've spent the entire last month trying to find the cheapest parts with the greatest value. This is what I've came up with http://pcpartpicker.com/p/2ptmB can you share your oppinions?
Thanks in advance
Thanks in advance
Closed loop watercoolers are of very limited use. Dual rad air coolers like the NH-D14 perform better for less money. Otherwise, looks good, though you will need a better PSU if you want to xfire.
You might want to look at something like this. All based on your build. 8320 is a good value vs 8350. It's a bit cheaper and you can OC it. Assuming you don't need a hard drive as one is not your build. Alternatively, you can look into an i3 with a z87 mobo with plans to upgrade to an i5 k sku down the line.
http://pcpartpicker.com/p/2ptWM
Thanks, but what if I don't want to crossfire?
http://pcpartpicker.com/p/2puje
for a few more dollars you get alot more
Along with a shitty motherboard, yes.
So the Asus 660 costs me 1620HRK while the sapphire 7870 costs me around 1300HRK
Is it worth my money? Why? Cooler seems nice
Edit: The 660 is abour 300$ nad the sapphire is just a bit over 220$
There isn't the Visiontek 7950 anywhere in stores in my country
You probably won't find any HD 7950s in stock at a decent price anymore.
The Sapphire HD 7870 is faster than the GTX 660. The Sapphire coolers, both their Dual-X and Vapor-X coolers are great. I would go get the sapphire card.
