Review my build before I order
Alright gentlemen,so I have finally settled on my build.I would wish for your thoughts and reviews before I go ahead and order the parts.Any and all thoughts are welcome.The build is budget oriented and I have even gone a little beyond it
  1. CPU: AMD FX 6300
  2. CPU COOLER:CoolerMaster Hyper 212 EVO
  3. MotherBoard:Asus M5A99FX PRO R2.0
  4. GPU:Asus HD 7790 Direct CU
  5. RAM:Kingston Hyperx 2x4GB 1600Mhz 1.35V
  6. HDD:Seagate Barracuda 7200rpm sata3
  7. PSU:OCZ Silencer MK3 600W
  8. Case:Corsair Carbide 200R
  9. Monitor:dell ultrasharp u2312hm
  10.  Optic:Asus DRW-24B5ST OEM
Looks nice. Have fun with it. :)
Unless you plan to overclock, then get a better mobo.
That mobo is good for overclocking, not the best, but for its price its good. All I would change is get a WD Blue instead of the Seagate Barracuda. Your build looks really great, good job. :)
If I were you I would get a asus m5a97 2.0 and get a 7850 2gb or 7870.  Or just keep that motherboard and get a better gpu 7850 2gb are pretty cheap and the WD blue 1tb is a better option for hdd
http://pcpartpicker.com/part/asus-motherboard-m5a97r20
I would advise you to go with a 650 ti boost over a 7790, a 650ti boost will perform better, and you can get them for only $120 right now.
I like AMD more then Nvidia and I have looked at the performanse and benchmarks a lot.The difference in the price between the 7790 and 7850 2GB here is 60$
