I currently planning finish my 2nd build but also to revamp my 1st
which is my primary an needs better cooling for its 5600x an 1660 super oc
i figured while im at it id upgrade my gpu also to a 6700 xt an my mobo to a
MSI MPG B550I GAMING EDGE WIFI Mini ITX AM4
(over my aorus b450m only 1 m.2 slot) my 2nd mobo that i already have is a asrock b450m pro
that has 2 slot
an up my aio to the Arctic Freezer II 240mm version at the same time.
my house doesnt have the best cooling during the summer (avg peak 75deg ) with my
current Arctic Freezer II 120mm an corsair 275r air case my at load runs
at a avg of 66c on the cpu an 72c on the gpu
the case has a total of 6 noctua fans 4 x 120 (1 rear intake on 120 aio as pull )
( 3 x front as intake ) ( 2 x 140 as top exhaust )
this was the best config for me for summer temps for my current gear in use
i tried others this was best but still not ideal.
im hoping a bigger case with a large aio , more fans in a different config
might work better id like at least a 12 - 15deg shave on temps
this is my purposed revamp
https://pcpartpicker.com/user/DEADFRED55/saved/LJndbv
id like to go with a fractal torrent compact with all Noctua F12 industrialPPC-3000 PWM fans
swap the 1660 super oc with a PowerColor Fighter AMD Radeon RX 6700.
what do you think on this revamp idea ?
