I’m trying to get a Lenovo Mini PC running Proxmox to interface with a Dual Coral TPU. The system is a Lenovo M920Q running the latest BIOS and Proxmox 8.2.2. The TPU is installed in the Wi-Fi slot on the main board.
I dont have any Lenovos laying around but with some of them i needed to set the Wifi slot from Wifi to PCIE in the Bios to use any PCIE extension card in them.
Sometimes their wireless slots have a whitelist that only allows certain devices, other times it’s a CNVI slot instead of a PCIE x1 slot. I didn’t see it listed in the hardware maintenance manual one way or the other, nor the STH review, so not sure there but something to look into.
Dang, looked up some of the Lenovo suggested WLAN cards… they might be CNVi cards. I think you have it!
I’m getting a pcie → M.2 board because I already have the special pcie riser card. Ill test and report back
Hi’ I have same system and plan to install dual edge coral to
above you mention “Dual Edge TPU Adapter B+M Key” where do you install it ?
in back of the mini pc m.2 M key or use riser with adapter sabrent pcie to m.2 M key and then use “Dual Edge TPU Adapter B+M Key” to install dual edge tpu ?
Sorry that i didn’t see this. hope you were able to figure this out. The model of machine I had has a weird pcie-ish connector on the top edge opposite the cpu. You have to get the little lenovo riser (found mine on ebay) and kinda cram it all in there, but it should fit.
