DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ “${next_entry}” ] ; then
set default=“${next_entry}”
set next_entry=
save_env next_entry
set boot_once=true
else
set default=“0”
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option=“–id”
else
menuentry_id_option=“”
fi
export menuentry_id_option
if [ “${prev_saved_entry}” ]; then
set saved_entry=“${prev_saved_entry}”
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry=“${chosen}”
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root=‘hd0,msdos5’
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos5 --hint-efi=hd0,msdos5 --hint-baremetal=ahci0,msdos5 34bcefbc-4e41-4130-b7e9-0180488b4e75
else
search --no-floppy --fs-uuid --set=root 34bcefbc-4e41-4130-b7e9-0180488b4e75
fi
font=“/usr/share/grub/unicode.pf2”
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if [ “${recordfail}” = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
Fallback normal timeout code in case the timeout_style feature is
unavailable.
else
set timeout=5
fi
fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
insmod part_msdos
insmod ext2
else
fi
insmod png
if background_image /usr/share/desktop-base/kali-theme/grub/grub-4x3.png; then
set color_normal=white/black
set color_highlight=black/white
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload=“${1}”
set linux_gfx_mode=
export linux_gfx_mode
menuentry ‘Kali GNU/Linux’ --class kali --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-simple-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
echo ‘Loading Linux 4.19.0-kali4-amd64 …’
linux /boot/vmlinuz-4.19.0-kali4-amd64 root=UUID=34bcefbc-4e41-4130-b7e9-0180488b4e75 ro initrd=/install/gtk/initrd.gz quiet
echo ‘Loading initial ramdisk …’
initrd /boot/initrd.img-4.19.0-kali4-amd64
submenu ‘Advanced options for Kali GNU/Linux’ $menuentry_id_option ‘gnulinux-advanced-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
menuentry ‘Kali GNU/Linux, with Linux 4.19.0-kali4-amd64’ --class kali --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.19.0-kali4-amd64-advanced-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Kali GNU/Linux, with Linux 4.19.0-kali4-amd64 (recovery mode)’ --class kali --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.19.0-kali4-amd64-recovery-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.19.0-kali4-amd64 root=UUID=34bcefbc-4e41-4130-b7e9-0180488b4e75 ro single initrd=/install/gtk/initrd.gz
menuentry ‘Kali GNU/Linux, with Linux 4.19.0-kali3-amd64’ --class kali --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.19.0-kali3-amd64-advanced-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo ‘Loading Linux 4.19.0-kali3-amd64 …’
linux /boot/vmlinuz-4.19.0-kali3-amd64 root=UUID=34bcefbc-4e41-4130-b7e9-0180488b4e75 ro initrd=/install/gtk/initrd.gz quiet
initrd /boot/initrd.img-4.19.0-kali3-amd64
menuentry ‘Kali GNU/Linux, with Linux 4.19.0-kali3-amd64 (recovery mode)’ --class kali --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-4.19.0-kali3-amd64-recovery-34bcefbc-4e41-4130-b7e9-0180488b4e75’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.19.0-kali3-amd64 root=UUID=34bcefbc-4e41-4130-b7e9-0180488b4e75 ro single initrd=/install/gtk/initrd.gz
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/30_os-prober
menuentry ‘Windows 10 (on /dev/sda1)’ --class windows --class os $menuentry_id_option ‘osprober-chain-B6C09986C0994E0D’ {
insmod part_msdos
insmod ntfs
set root=‘hd0,msdos1’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 B6C09986C0994E0D
else
search --no-floppy --fs-uuid --set=root B6C09986C0994E0D
fi
parttool ${root} hidden-
drivemap -s (hd0) ${root}
chainloader +1
menuentry ‘Manjaro Linux (18.0.4) (on /dev/sda2)’ --class manjarolinux --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-60fbe4f3-3861-47ce-8d83-6dd65b1f32df’ {
insmod part_msdos
insmod ext2
set root=‘hd0,msdos2’
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 60fbe4f3-3861-47ce-8d83-6dd65b1f32df
else
search --no-floppy --fs-uuid --set=root 60fbe4f3-3861-47ce-8d83-6dd65b1f32df
fi
linux /boot/vmlinuz-4.19-x86_64 root=UUID=60fbe4f3-3861-47ce-8d83-6dd65b1f32df rw quiet
initrd /boot/intel-ucode.img
submenu ‘Advanced options for Manjaro Linux (18.0.4) (on /dev/sda2)’ $menuentry_id_option ‘osprober-gnulinux-advanced-60fbe4f3-3861-47ce-8d83-6dd65b1f32df’ {
menuentry ‘Manjaro Linux (on /dev/sda2)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-4.19-x86_64–60fbe4f3-3861-47ce-8d83-6dd65b1f32df’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Manjaro Linux (Kernel 4.19.32-1-MANJARO x64) (on /dev/sda2)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-4.19-x86_64–60fbe4f3-3861-47ce-8d83-6dd65b1f32df’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Manjaro Linux (Kernel 4.19.32-1-MANJARO x64 - fallback initramfs) (on /dev/sda2)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-4.19-x86_64–60fbe4f3-3861-47ce-8d83-6dd65b1f32df’ {
insmod part_msdos
insmod ext2
else
fi
initrd /boot/initramfs-4.19-x86_64-fallback.img
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z “${config_directory}” -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
