I’m abount to try a complex homelab setup - anyone want to join in the fun as I document and provide suggestions? If so read on (quite long!)
I watched a YT video by Network Chuck (DO NOT design your network like this!! ) discussing network architectures and thinking this is not something easy to practice on a home network. Then I ended up on this page - OPNsense setup with bridged interfaces, VLAN and RTSP not worki- and thought I could try that!
I have an Opnsense router, 2 Mikrotik routers and a Netgear 10Gb switch, so I want to try a toplogy like the example on this page: Topology of a STP enabled network
SW1 would be Opnsense, SW2 and SW3 the Mikrotik, and SW4 the Netgear. The topology is easy - just plug wires in ports. The configuration is the harder, fun part…
Constraints:
- Avoid bridges if possible (Opnsense document suggestion)
- Keep Internet access open (as little downtime as possible) fo2 Wi-Fi and wired PC and wired NAS.
- The dual links in the toplogy will be 802.3ad LAGGs.
- The Opnsense connects to the Internet. This is a single point of failure. Cost constraints mean this has to stay as s SPOF.
- No more hardware purchases.
- Mikrotik must be in RouterOS (not SwOS) - just because passwords aren’t strong enough under SwOS.
Stretch Target - I have 2 Engenius EWS377AP currently as separate SSIDs on different ports of the Opnsense. Can I make this more resilient in itself, and as resilient as possible from the wired network.
As I work my way through this I will document the adventure, but feel free to join in at anytime!
Documentation
Opnsense: Supermicro SYS-E300-9A with 4 1Gb ports (2 used for WAN LAGG) and 6 10Gb ports (4 available, 2 unusable, but not in use)
2xMikrotik CRS312-4C+8XG-RM (12 10Gb ports, 4 will be used for interconnecting LAGG)
Netgear XS508 (LAGG, VLAN support web interface)
Engenius EWS377AP support 2,5Gb, so use 10Gb ports if available, otherwise 1Gb.
Initial plan:
- Initial configuration of Opnsense with WAN port and 1x10Gb to connect to switches. Daisy chain switches SW2-3-4 without return to SW1 at present. Configure switch web interfaces (passwords etc.) and check for Internet access. Connect wired devices.
