I require help interpreting SMART results. I knew in advance the disk was not perfectly fine so I ran an extended selftest. I am unfortunately unable to determine if the disk would still be fine to use for a ZFS pool.
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WDD4E5EN7892
LU WWN Device Id: 5 0014ee 261de13e5
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Mar 15 20:23:21 2021 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (53520) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 535) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1560
3 Spin_Up_Time 0x0027 203 171 021 Pre-fail Always - 6841
4 Start_Stop_Count 0x0032 095 095 000 Old_age Always - 5015
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 199 000 Old_age Always - 0
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11050
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 096 096 000 Old_age Always - 4805
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 146
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4909
194 Temperature_Celsius 0x0022 119 108 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 11020 130281
# 2 Extended offline Completed: read failure 90% 10979 130280
# 3 Short offline Completed without error 00% 7678 -
# 4 Short offline Completed without error 00% 6261 -
# 5 Short offline Completed without error 00% 5542 -
# 6 Short offline Completed without error 00% 4612 -
# 7 Short offline Completed without error 00% 4273 -
# 8 Short offline Completed without error 00% 3476 -
# 9 Short offline Completed without error 00% 3268 -
#10 Short offline Completed without error 00% 3089 -
#11 Short offline Completed without error 00% 3005 -
#12 Short offline Completed without error 00% 2827 -
#13 Short offline Completed without error 00% 2655 -
#14 Short offline Completed without error 00% 2420 -
#15 Short offline Completed without error 00% 2274 -
#16 Short offline Completed without error 00% 2008 -
#17 Short offline Completed without error 00% 1749 -
#18 Short offline Completed without error 00% 1328 -
#19 Short offline Completed without error 00% 1108 -
#20 Short offline Completed without error 00% 995 -
#21 Short offline Completed without error 00% 776 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Thank you!
