How do I remove this indicator that keeps popping up, it recently started happening and I have no software that should be causing this. It also alt tabs me out of full screen games.
Click on Start
type Keyboard in the search field
double click on the Keyboard options
under the Key Settings tab, go to the Key Settings List
Locate and double click on CAPS LOCK
on the menu you should see where it says "Display CAPS LOCK status on screen"
Click the check mark box, and click Finish
Hope this helps!
Unfortunately I dont have any key setting tabs, the hardware tab just displays drivers and interface devices.
would you mine posting a screenshot of the settings tab
Does it happen to be a Lenovo Notebook you're on? if so, try this (Or even when its not a Lenovo)
No its a custom built pc. My PC doesn't have that on screen display tab. This is pretty frustrating. Thanks though.
Well I figured it out, OOCT the tool that I used to test my overclock was somehow causing it.
You can also do this if it comes back.
This notification is handled by BTTray.exe process. You must edit the following registry entries to get rid of this alert.
Hold Start > R or search for regedit
Navigate to: HKEY_LOCAL_MACHINE > SOFTWARE > Widcomm > BTConfig > General > KeyIndication
Change the value of "KeyIndication" from "1" to "0"
Reboot..
And the nasty notification should be gone!
