Remounting a Coolmaster H90
Anyone tried remounting one of these? The double ended stickers for the back panel of the motherboard is really annoying to take out. Is there anything to replace them. (I ripped it in half while trying to take them out)
Dont worry those foam bits tear all the time.
You can get those adhesive foam/rubber etc barriers from any home depot/hardware store. Just grab close to the same thickness. Even if the sections are bigger, just cut em to size.
I have a roll like this that I use from time to time. http://www.ebay.com.au/itm/Single-Sided-Adhesive-Foam-Tape-3mm-x-25metres-Sold-Per-Roll-/141098391775?pt=AU_Building_Materials&var&hash=item20da1e98df&_uhb=1 - good for all sorts of things.
Oh snap, thats man, I needed a solution to that for a while now :D
