There is a problem with the linux pc at work and we trying to remote connect to the box. Any tips?
SSH?
Do you need graphical or just a terminal? Is this thing on a domain? There is not enough information to help you right now.
You can do remote rendering with X by using ssh -X <ip/machine name>
If you need just terminal, ssh <machinename/ip>
But does this PC already have something installed that will allow connection, or someone will do it locally? Otherwise it’s …
Lots of programs for this purpose with gui … rdp via vpn or x2go.
As a service option, I recommend to equip with ipkvm which would be connected to a problematic pc as a last resort if the OS fell completely.
We need more context to help.
- Protocol,
- error message or behavior,
would be a great start.
