I found a cheap Tintri VMStore T5080 Appliance on Ebay for my homelab. At the moment I use a Synology NAS (RS3617rpxs) as iSCSI Storage for my VMs. The solution works, but is not optimal because of the lack of redundant controllers.
Unfortunately, the Tintri was delivered without an operating system. Consequently, I contacted the support to get access to the required materials. I was then told that I needed an active support contract so that they could help me. However the device will no longer be supported in less than a year (end of life) and I would have to pay the last two years retroactively in which the device was inactive.
Lets say I got the installation files anyway … I still am unable to install the OS.
Now to my question: Does anybody have experience in installing a Tintri device and may help me? I suspect that I have to change some bios settings, because the battery was empty and all the settings got reset.
I get to the point where the rpm file gets copied and validated. After that a bunch of errors get spit out.
It would be a shame if a perfectly fine appliance couldn’t be used.
Any help is appreciated. Thank you in advance!
