KVM Model:
USW-KM-304
Problem:
*Is there a known problem with Redragon keyboards and hotkeys? I have several Redragon keyboards:
K596RGB
K585RGB
K615-R
K629-RGB
None of them work. They don’t have options to turn off the nkro. Well, K596RGB can turn key-rollover to 16-keys, but it still doesn’t work.
My current workaround is the Redragon M908 mouse, which has at least one key (key 4 on the top, the “fire” key), and macros there do work, though it cannot be programmed while plugged into an HID port. For anyone who has this mouse and a similar problem, make sure to have 10ms delay between key presses during your recording. Other keys on the mouse might work with macros (on the keypad 1 and 2 definitely work), but definitely not all, the keys that default to mode+/- do not.
I thought these would all work when I bought this switch because Windows has them listed as HID devices, and I didn’t look into it too carefully. I am assuming there is no way to fix this. It’s annoying.*
Other Notes:
Nothing that I can think off.
