I think the terminology is ‘Mini-PC’ because a NUC is a strictly Intel product. But yes the Qotom box I have is a Chinese mini-pc. No problems with the product other than what I have done to it. It sits in a cramped 4u closet with a patch panel, power strips, hdhomerun, switch, and a few other things. Although there is no air flow, the temperatures seem fine. The box does a good job distributing heat (Fanless, but all aluminum exterior). I have had it for about 4 months now, so I can’t attest to it’s longevity.
When I was looking up different options for what I wanted, I asked myself the following questions:
- How much power will this use?
- Am I better off buying a pre-made device or building my own?
- How much space will this use?
- How long will this solution last?
I used to have a Q6600 box that was a mini tower, and it would whine like a banshee sometimes. It used a noticeable amount of power, and was not able to easily fit where I wanted it (I basically had it sitting on my electrical box half leaning on a shelf). I didn’t expect it to last that long, so I looked into something better.
The newest versions of pfSense require AES-NI encryption capable processors, so I went to the Intel ARK system and narrowed down my selection to chips that fit the bill. Narrowed it down to processors that used less than 25W, compared results. I knew that the J1900 boxes were all popular, but didn’t support AES-NI. Eventually I saw that a J3455 Embedded Asrock Board would do OK, but would use more power than I wanted. The cost of building an ITX system outweighed the cost, used more power, and had less performance for my goals so I decided on a pre-built unit.
I have seen decent reviews for the ProtectLi boxes on Amazon, but they were more expensive than the Qotom variant. Since I was planning on installing my own drive for security’s sake, I wanted the best price on the firewall shell. There are numerous boxes out there, all with differing capabilities. For mine I wanted 1Gb throughput from my desktop to my WAN, so I made sure I got a box with that. I also made sure that the NIC’s were intel based due to pfSense’s hardware requirements. I used a Syba quad port NIC with my Q6600 build, and it didn’t register with pfSense. I also tried to use an on-board Realtek chip that didn’t use it’s full throughput. Then, I scored the pfSense forums for different gigabit guides/results and I found a thread where someone else recommended the exact same box I ended up buying.
So for me, I ended up with a dedicated firewall appliance, it cost more than if I absolutely DIY’ed something, but that cost will be reflected in both power savings over time, and in how much space I am saving at my house. I have a quiet box, that works well, that hasn’t given me any cause for alarm. If I could go back, I wouldn’t change my decision (although I’m sure I could have gotten away with the lesser model, I didn’t want to risk the $75 difference after dropping about $300).
I hope this helps OP.
