hello everyone, i just bought all the parts to my new pc and they have arrived, i put all the parts together with help of a friend in the IT industry, when we were done and turned the computer the cpu light was red and there was no blue screen or anything, also the usb ports dont work either. i have a AMD fx 8320 and a Asus M5A990X EVO R2.0 AM3+ motherboard.
Try another psu first, Coolmax units are beyond terrible and are dangerous. Good for starting fires but not much else.
Otherwise - try barebone build - cpu/hsink & fan, 1 stick of ram, keyboard, gpu + monitor, nothing else connected. If it posts from there could be either of your drives that are the issue or some other process in the build that went pear shaped.
Either way, if it does post and the psu does for whatever reason work, see if you can swap it for a better unit. Honestly they are up there with the likes of SHAW psu's in terms of misleading power figures and build quality.
thanks for the reply deejeta, i performed a barebone build as recommended with my current psu and with a friends psu but i got the same result, i did more research and i started to see people say that the mobo does not recognize the fx series of amd processors and that a bios update could solve the problem.
do u think that this could work, if so how do i perform such a task without any visuals from my monitor.
It must be really old stock if it hasnt got the 1604 bios... Bugger.
Looks like you'll have to source an old supported cpu >link<, put one it and go into BIOS to update it with the 1604 file (find this file on the motherboard's support page).
thanks for all the advice, it turns out that the psu was not producing the amount of power advertised and the psu did not come with a 8 pin power cord for the cpu.
